TwinTurbo.NET: Nissan 300ZX forum - injector problems
Subject injector problems
Posted by BradleyTT(OK) on April 20, 2008 at 10:47 PM
  This message has been viewed 209 times.
Message Dove to my dad's for dinner ~3 blocks away car ran ok, seemed alittle hesitant when it first started now when i came home it wasn't firing on all
cylinders. Got it home and started pulling coil packs to figure out what
cylinder. I pulled cylinder #3 i think (passenger side middle) and the car
didn't change it's idle. So i swapped coil packs with cylinder passenger
front and nothing changed. I did the screwdriver to the injector trick and
heard a ticking but when compared to a known good cylinder it sounded noticeably different. I've pulled the CAS connection and tried cleaning it
then plugged it back in with no effect. I've also checked the PTU
connections. I'm going to ohm the injector tomorrow. My question is, is
this just bad luck and my injector went kaput or do you think i have
electrical gremlins. Granted i know that ohming the injector tomorrow
will and answer the question completely but i figured i would ask
anyway. Also if it's the injector, i'll be needing an injector for a 93' TT.
"shaving it always makes it look bigger" -ELDIABLO
